Heat Flux at Internal walls or Fluid Solid Interface
Old   September 28, 2012, 15:49
Default Heat Flux at Internal walls or Fluid Solid Interface
Mahendran
Mahi is on a distinguished road
Hi All,
I am new to this forum and this forum helped me in clarifying many doubts . Thanks for the useful stuff being posted here and especially many thanks to Glenn.
I am doing CFD CHT analysis of combustor burner plate and above there are set of cooling holes required to cool the burner plate.I have the heat flux value from the combustion simulation which needs to be applied at one side of the burner which has some thickness . For CFD purpose we have extended the domain below burner plate and made it has outlet boundary , here we have fluid-solid interface in which heat flux needs to be supplied . I tried following things in CFX
1.In the fluid-solid interface , on the solid side provided heat flux as boundary source and fluid side interface there is no specification .
2.Using non-overlap conditions ,for the solid side interface I have provided the heat flux. (here the supplied heat flux is not taking)
3.There is no fluid solid interface , on solid side wall supplied heat flux and fluid side as default adiabatic wall .
Out of this three methodology , 2 method is not physical as supplied heat flux is not taking or CFX solver does it like that.
I need some suggestion imposing the correct boundary condition or methodology for applying heat flux at the solid side boundary .
Mahi is offline   Reply With Quote
Old   September 28, 2012, 21:08
Erik
evcelica is on a distinguished road
I would say #1 is correct but its hard to understand exactly what you are doing without pictures.
evcelica is offline   Reply With Quote
Old   September 30, 2012, 14:17
Antanas is on a distinguished road
Hmm... if you know Heat Flux value then maybe you should simulate things in solid domain only, without flow or vice versa. Or if your Heat Flux is the addition to convective heat flux between fluid and solid then, I think, you should follow #1.
BTW did you activate "Heat Transfer" under "Additional Interface Models" in interface specification?
Antanas is offline   Reply With Quote
Old   October 1, 2012, 03:18
Mahendran
Thanks for the reply, attached is schematic representation of my model . Yes, I have enabled heat transfer in the "Additional Interface Models" . If option 1 is correct , then heatransfer will happen on both sides of the plate and temperature will be different. The outlet extension is only CFD part of it , but real boundary stops at burner plate .
My understanding , without interface feed the heat flux on solid side wall and fluid side be adiabatic .
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
How to define the heat flux in the interior interface between two phases fangdian FLUENT 1 November 18, 2013 08:23
heat flux at fluid solid interface Studentdrak CFX 6 January 30, 2012 12:05
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
wall heat flux between two fluid zone!!! Asghari FLUENT 2 August 25, 2006 11:11
