Preformance of Ansys CFX on a Linux Cluster
Old   September 25, 2012, 03:44
Default Preformance of Ansys CFX on a Linux Cluster
Jens Roued
roued is on a distinguished road
We are just installed a new Linux cluster for running Ansys CFX.
Cluster is setup using the latest Intel Xeon E5-2680 @2.7 Ghz and infiniband network.
However when comparing to our older workstations (Intel Xeon X5570@ 2.93 Ghz) we are not seeing the speed-up that we have hope for.
The cases we are using for benchmark are fairly large (more than 50 mill cells) and are about wind environment in urban areas. But have also seen problem with other smaller flow cases. We are comparing the runtime for with:
Cluster:
1 blade using 16 core (2 x E5-2680), using infiniband
2 blade using 8 cores on each and using infiniband
Workstation:
2 x workstation (2 x X5570 in each workstation) connected through Gbit network.
The Intel Xeon E5-2680 contains 16 core and have a faster memory bus compared to the X5570. However the X5570 does a have a small lead regarding clock frequency.
Does anyon have experiance similar problem with the preformance of the
Xeon E5-2680 in a cluster environment ?
And does anyone have a possible solution to the preformance problem ?
Thanks in advance,
Roued
roued is offline   Reply With Quote
Old   September 25, 2012, 05:12
Sainath
sainath.s@tdps.co.in is on a distinguished road
Because it is 2.93GHz against 2.7Ghz.
sainath.s@tdps.co.in is offline   Reply With Quote
Old   September 25, 2012, 09:08
Clock frequency means very little by itself for CPU speed. You really need to look at reliable benchmark speeds to have any rational basis to compare CPUs, my favourite benchmark is the CPU2006fp benchmark from spec.org.
Can you describe what performance is poor and how you measured it? Some context would be handy it you want us to make comments about what is wrong.
Old   September 30, 2012, 08:07
Jens Roued
Problem solved. Firmward updated on the Mallanox infiniband, and
a missing riser card was installed.
Preformance now show super-linear speed-up on all Ansys CFX
benchmark cases (IndyCar, Internal, Airfoil etc).
Best Regards
Roued
ANSYS CFX with Remeshing in ICEM CFD adeban CFX 21 March 29, 2021 07:06
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 17:50
Ansys Workbench (CFX) bucket problem njsavage CFX 1 April 30, 2009 10:51
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 10:48
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
