September 12, 2012, 03:04 |
Solver error
Arash
Rep Power: 15 |
I'm following the procedure for tracer analysis as on here: http://www.cfd-online.com/Forums/cfx...lysis-cfx.html But when I want to set the steady state .res file as the initial value file for transient case, I get this error from solver: "You cannot use a CFX-5.3 solver input file with the CFX-5.4 initial values" Please, any help is appreciated. |
September 12, 2012, 09:19 |
Rep Power: 144 |
The error message is pretty clear. It tells you exactly what the problem is.
If you are using CFX 5.3 or 5.4 then you are using something like 10 year old software. You really need to update to the current version. |
September 12, 2012, 18:06 |
Arash
Rep Power: 15 |
Thank you for your reply Glenn.
But a colleague helped me with that. It was due to running the steady state condition in Workbench and trying to run the transient in CFX standalone. |
initial result file, solver, steadty state, tracer |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 07:12 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
