shaft power versus RMP curve in wind turbine simulation
Like Tree1Likes
Old   November 1, 2012, 16:03
Paulo
strobel is on a distinguished road
Originally Posted by zhenduan306 View Post
Unfortunately, I don't have time to continue it. If you just want to get Cp and Tip Speed Ratio curve, I suggest you use Qblade. It is a very good software. You can download from websit. Just google it.
I'm already using BEM to get Cp, but when i use CFX to get similar values it don't happen.s
strobel is offline   Reply With Quote
Old   November 2, 2012, 06:43
Kyriakos Vafiadis
k.vafiadis is on a distinguished road
Send a message via Skype™ to k.vafiadis
Sounds pretty reasonable. A BEM software works very different than CFD. BEM under predicts the overall performance of a wind turbine and over predicts the peak power. Also CFD is as accurate as the model and boundary conditions used.
I am also modelling wind turbines and in my opinion the only safe way to judge the BEM or CFD results is an experimental reference.
Kyriakos Vafiadis
Mechanical Engineer, PhD candidate
k.vafiadis is offline   Reply With Quote
Old   November 2, 2012, 07:23
Paulo
Even compared with experimental reference, my Cp in
CFD is so different.
Basically, at 5RPM i get Cp of 0.13 in CFX and 0.17 in BEM. But, at 10RPM i get Cp of 0.61 in CFX and 0.42 in BEM. So, is evident something is wrong with my simulation in CFX.
Old   November 2, 2012, 08:24
Kyriakos Vafiadis
Are you sure about the RPM you use? What's your reference CP(@what RPM, wind speed)?
Kyriakos Vafiadis
Old   November 6, 2012, 07:37
Paulo
I'm sure about RPM i'm using. My reference of Cp is BEM. Im getting Cp of 0.65 at 10RPM, 2.5m/s of wind speed and my turbine has a diameter of 10m. So, in BEM i get a CP of 0.4 to theses conditions. So, something is wrong in my simulation.
Old   November 6, 2012, 10:40
michael
zhenduan306 is on a distinguished road
I guess your simulation has some problems. You set wind speed at 2.5m/s, if your Tip speed ratio is 7, diameter is 10m. The rotating speed is 33.44RPM, not 10RPM.
In my simulation, from cut-in speed (2.5m/s) to around 10m/s, the Cp is almost same as in BEM. But, in high wind speed such as above 12m/s, the Cp is very high. The reason is I didn't stall the rotating speed in a fix number (such as 60 RPM). I just calculate RPM according to Tip Speed Ratio and wind speed.
How is your domain? Big enough? Moreover, meshing is another issue. You'd better refine your model, if it is coarse.
k.vafiadis likes this.
zhenduan306 is offline   Reply With Quote
Old   November 6, 2012, 22:04
Paulo
I'm doing a curve of Cp X Tip speed ratio, in this case i'm setting only to 2.5m/s of wind speed and increasing the rotation to see how Cp increase.
My domain is big enough as shown in CFX's lectures and my mesh is good aswell. I changed the distance between the blades and interface, and cp decrease. So, i'm gonna try this way now. Do you know how far your blade was from the interface between rotationary and stationary domain?
Old   November 8, 2012, 11:07
michael
Your blade's diameter is 10meter. At 2.5m/s, 5RPM means tip speed ratio(TSP) is about 1, Cp is 0.13. But, in 10RPM, TSP is about 2, Cp reaches to 0.42 in BEM. I think 0.42 is very high if TSR is 2. You know Betz limit is 0.59. Generally,the optimal TSR is 6 to 7.
Old   November 8, 2012, 11:11
michael
I created rotational and stationary domain in AWB. I know it.
By the way, if possible, you can post your simulation model. I think more guys can help you.
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
Vertical axis wind turbine simulation vincentwks ANSYS 0 April 10, 2012 05:27
1D analysis and simulation of gas turbine power plant sridhar.d009 Main CFD Forum 1 September 28, 2010 08:38
Pressure Drop/Porous Media within Shrouded Wind Turbine Simulation joshdsouza FLUENT 0 March 3, 2010 19:02
