August 22, 2012, 08:11 |
Oscillatory flow 101
Rep Power: 14 |
Hi all,
I am using CFX to model oscillatory flow in a bifurcation. BC's are inlet with a velocity defined by a trigonometric expression that I entered, outlet with a relative pressure of 0 and wall with no-slip condition. Initial values are zero for all velocities. Transient flow has been selected, and output control to print results every second. The mesh is a simple octree mesh. This is a simple situation but it just simply does not work, I was wondering if I am missing something obvious? Any help would be greatly appreciated, Andris |
August 22, 2012, 08:33 |
Lance
Rep Power: 22 |
August 22, 2012, 09:24 |
Rep Power: 14 |
Hi Lance,
here is the error message An error has occurred in cfx5solve: writemms exited with non-zero return code 11 I was wondering if this transient problem has to be done in a similar way to as it is done in the tutorials, i.e. taking initial conditions from a steady state domain? |
August 22, 2012, 09:38 |
Rep Power: 14 |
Here is the geometry I am using,
I readjusted the global initialization to a very small velocity in the y direction, I get the following error message ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ |
August 22, 2012, 10:16 |
Lance
Rep Power: 22 |
August 22, 2012, 10:21 |
Rep Power: 14 |
thanks for the link, instead of using an expression, I used an excel file, and got a solution, though the solution was very very bad, I am surprised it worked
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
Help on laminar oscillatory channel flow [Help needed - Urgent] | Dtkcby | Main CFD Forum | 0 | March 19, 2011 15:11 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
