August 22, 2012, 05:14 |
Two pressure inlets problem
George Sladkovsky
Rep Power: 14 |
Hello!
Sorry for my English. I have a problem with inlets in my model. I have 3 static pressure inlets and 1 static pressure outlet(i know that the pressure inlets are bad, but cant do anything about that). Two inlets have the same pressure and the other one have much higher pressure. High pressure inlet have no poblems. The problem with the low pressure inlets. After a certain amount of iterations (when the case starts to converge) one inlet cuts off (CFX places the wall in one inlet). I tried to put inlets as one BC and as different BCs with the same result. In theory the both low-pressure inlets should provide the same mass flow. The resulting mass flow (from Post) is equal with the calculated one but i cant understand why CFX tries to put all the mass flow from one inlet and cuts the other. Im using SST model with tetra mesh with boundary layer (i can use ICEM hexa but for the optimisation purpuses its easier to use tetra). Can anyone give me an advise with this case? Im adding the mass flow plot from CFX solver and streamlines from Post. http://img515.imageshack.us/img515/6...solverplot.jpg http://img820.imageshack.us/img820/1...ejpipescom.jpg Thank you for your attention! |
August 22, 2012, 07:50 |
Rep Power: 144 |
There is nothing wrong with pressure inlets. If you know the pressure at an inlet then you specify the boundary condition as a pressure inlet.
CFX is probably predicting reverse flow at one inlet. Have a close look in CFD-Post and try to see it. This might be real, or it might be just a numerical thing which will disappear with tighter convergence. |
stagnation pressure boundary problem | mbgnfrx2 | STAR-CD | 2 | November 26, 2012 00:55 |
Pressure calculation problem | maolongliu | OpenFOAM | 1 | August 15, 2010 09:05 |
problem with pressure force report | jvd | FLUENT | 0 | August 3, 2010 03:19 |
pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 11:52 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
