August 19, 2012, 11:16 |
precise water / air boundary
Heinz Mutzner
Rep Power: 14 |
I just succeeded in doing the 2d bump tutorial.
Now, I would like to calculate a more precise water / air boundary. At the moment, it looks like a continuum over 4 mm height. I would appreciate some hints on the relevant parameters. I already increased the max number of refinement steps in the mesh adaption menu of cfx pre. This didn't give any significant change. Cheers Heinz |
August 19, 2012, 20:20 |
Rep Power: 144 |
The best way to improve resolution of the free surface is to use a finer mesh in the region of the free surface. I prefer a fine fixed mesh and adaptive mesh refinement has never worked for me with free surfaces very well.
August 21, 2012, 22:41 |
Erik
Rep Power: 23 |
Not sure on this, but I seem to remember using a specified blend factor of 1 will aid in separating the two fluids more precisely (less smearing) since it is true second order; feel free to call my bluff anyone.....
Glenn is absolutely correct though, as usual, a finer mesh will of course give you finer resolution. |
August 22, 2012, 05:04 |
#4 | |
Dynampally Pavitran
Rep Power: 16 |
More information on this can be found in CFX Modeling guide --> Advection scheme. I would like to know, What is the effect, when the partition (while solving in parallel mode) lies along the Free surface? Sometimes, I have observed that the solver crashes due to build up of unphysical values of Eddy viscosity at the partition zone. |
August 22, 2012, 07:45 |
Rep Power: 144 |
I'll call your bluff Erik
For free surface models you should use the default compressive scheme for the volume fraction equation. This scheme is specifically designed to capture sharp interfaces and no other schemes will work well at all. For the momentum equations use whatever scheme is sensible - hybrid (with a large blend factor) or high res are the normal choices. You should try to avoid havign partition boundaries lying along the free surface. This can cause convergence difficulties. You might need to define a partitioning algorithm to avoid this happening. |
August 23, 2012, 23:40 |
Erik
Rep Power: 23 |
Yeah, I don't know where I heard that. I thought a read it somewhere but it was a long time ago. Thanks for correcting me.
cfx, free surface flow, open channel flow |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Simulating A water bubble in air with periodic boundary condition | cubicmatrixist | Main CFD Forum | 0 | October 14, 2010 13:26 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Solver error message!!! | IoSa | CFX | 1 | September 14, 2006 05:48 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
