FSI simulation in ansys cfx
Old   August 11, 2012, 08:18
Default FSI simulation in ansys cfx
arash ghorban-nia
Arash67.m is on a distinguished road
Send a message via Yahoo to Arash67.m
hi every one
I've done a one way FSI simulation in ansys cfx on an artery ,now I'm working on a two way one,but i have some problems. for example in two way simulation we should define the solid and fluid geometries together, so on wich part should we insert the fluid solid interface , on fluid or solid or both!?
I've applied it on both parts but still I have this error in solver, hope some one knows about this problem
| ANSYS CFX Interpolator 12.1 |
| Version 2009.10.14-23.08 Thu Oct 15 04:18:41 GMTDT 2009 |
| Executable Attributes |
| double-int32-64bit-novc8-noifort-novc6-optimised-supfort-noprof-nos|
| Copyright 2009 ANSYS Inc. |
| Job Information |
Run mode: serial run
Host computer: ARASH-PC
Job started: Sat Aug 11 15:29:06 2012
| Memory Allocated for Run (Actual usage may be less) |
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 1219.9 75.62 47.16 9530.3 604.99
Integer 1460.9 90.56 56.47 5706.5 362.25
Character 1648.2 102.18 63.72 1609.6 102.18
Logical 82.4 5.11 3.19 321.9 20.44
Double 117.1 7.26 4.53 914.6 58.06
Details of error:-
Details of error:-
Error detected by routine MAKDAT
CDANAM = IZN CDTYPE = INTR ISIZE = 1
CRESLT = OLD
CRESLT = OLD
Current Directory : /INTERP/OLD1/MESH/TSTEP0/CLOOP0/ZN1
| ****** PROBLEM REPORT ****** |
| Subsystem: Input |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: C:\Program |
| Files\ANSYS Inc\v121\CFX\bin\winnt-amd64\double\solver-hpmpi.exe |
| exited with return code 1. |
| ANSYS Solver terminated with return code 3840 |
| The results from this run of the ANSYS solver have been written to |
| C:\Users\Arash\AppData\Local\Temp\FSI paye |
| kootah_4052_Working\dp0\CFX\CFX\Work1\blood_002.an sys |
| The following user files have been saved in the directory |
| kootah_4052_Working\dp0\CFX\CFX\Work1\blood_002: |
| job |
This run of the ANSYS CFX Solver has finished.
Arash67.m is offline   Reply With Quote
Old   September 29, 2017, 10:52
AJ
AJ FSI is on a distinguished road
Hope you got the solution for error code 3840 and 1,
Could you please share with us what are the reasons for the error code 3840 and how to solve it, Please!
Thanks!
AJ FSI is offline   Reply With Quote
Transient Simulation in ANSYS CFX ylm054 CFX 7 April 25, 2016 21:05
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 22:01
ERROR #002100056 CFX FSI problem Hongdao CFX 0 November 10, 2010 04:58
Fsi ansys cfx? Mostafa.T CFX 5 March 31, 2010 11:16
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 14:24
