specific heat capacity changing with temperature
Old   July 12, 2012, 12:41
Default specific heat capacity changing with temperature
Ahmet
a_cucen is on a distinguished road
Dear all,
I have a case that specific hat capacity changes with temperature. After solver manager starts , I get this failure. What can I do to solve this problem?
| Initial Conditions Supplied by Fields in the Input Files |
Domain Name : ICEngine
Mesh Coordinates
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Specific heat information for fluid component "C7H16l" is either |
| missing or invalid. Supported formats are: NASA polynomials, Zero |
| pressure polynomials or constant values for the specific heat. |
| Writing crash recovery file |
| Message: |
| Stopped in routine SU_PROP |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
a_cucen is offline   Reply With Quote
Old   July 12, 2012, 19:02
Default HI
Danial
Danial Q is on a distinguished road
How did you define your Cp as function of time, I mean which format?Because ERROR clearly describes the allowable formats, you can use. If you have specified as expression then post it here.
Thanks
Danial Q is offline   Reply With Quote
Old   July 12, 2012, 20:29
Ahmet
I defined Cp as a function of temperature. I imported a table that shows Cp changes with temperature.
Old   July 13, 2012, 00:31
Default HI
Danial
Then this error clearly states that your table has some problem (i.e format/coding error) because solver is unable to read it. Without looking at your table, i cant be sure about anything. But you may use Polynomials format by developing an equation or writing a CEL Expression. Have you selected the real gas (EOS) option for your material because I guess table format is supported only for real gas problems. These all are possibilities, i can think of right now.
Old   July 13, 2012, 05:37
Ahmet
Here is an example of my table. I have imported this table and if my values are out of the table, it must be extrapolate. Is there something wrong about my table?
Temperature (K) Cp (J/g*K)
186,72 1,9651
188,81 1,9673
190,9 1,9695
192,99 1,9718
195,07 1,9743
197,16 1,9768
199,25 1,9794
201,34 1,9821
203,42 1,985
205,51 1,9879
Old   July 13, 2012, 21:21
Default HI
Danial
I already told you that (.rgp) format table is used to define some real gas properties of user material. So, you can add that table by choosing material properties option to table and filling component and file name. Else, you can just use ZERO pressure POLYNOMIAL if your Cp and Enthalpy of materials are only function of temps. In my opinion, it would suit you the best.
For more details you can just read ansys cfd solver theory guide and tutorials.
Cheers
Old   July 14, 2012, 06:03
Ahmet
Dear Danial, I have found that information that If I want to choose heat capacity changing with temperature, I have to use Nasa polynomials. So I' m trying to use Nasa polynomials. Thank you for your help.
Old   July 16, 2012, 13:25
cfdgremlin is on a distinguished road
Dear Ahmet,
is the Cp you are trying to define being applied to a particle phase, by any chance?
CG
cfdgremlin is offline   Reply With Quote
Old   July 17, 2012, 03:12
Ahmet
dear cfdgremlin,
I couldn' t define cp from table values but I' m using Nasa Polynomials now.
Old   December 12, 2012, 17:25
Saima
Saima is an unknown quantity at this point
Could you pls tell me how you implemented polynomial for specific heat capacity in CFX pre?
Best Redards,
Saima
Saima is offline   Reply With Quote
Old   October 6, 2015, 19:15
ana
antara is on a distinguished road
Originally Posted by a_cucen View Post
dear cfdgremlin,
How do you get Nasa Polynomials? Can you please explain it? I'll have to use Real gas property for supercritical simulation.
antara is offline   Reply With Quote
Old   October 7, 2015, 02:24
Antanas is on a distinguished road
Material Props -> Specific Heat Capacity Option = NASA format
Antanas is offline   Reply With Quote
Old   October 7, 2015, 12:36
ana
Which CFD code are you using for your case? I'm using ANSYS Fluent. I couldn't find the NASA format on Specific Heat Capacity Option under material props option.
Old   October 7, 2015, 12:44
Opaque will become famous soon enough
You are asking in the wrong forum
Opaque is offline   Reply With Quote
Old   October 8, 2015, 01:13
This is CFX forum, so my post concerns CFX.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 10:32
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
VISCOUS heat dissipation Joseph CFX 0 October 1, 2004 09:52
