Help for tutorial 17 in Fortran Compiler-CFX13.0
Old   July 10, 2012, 06:20
Default Help for tutorial 17 in Fortran Compiler-CFX13.0
eva yang
shenlan05 is on a distinguished road
My machine is Windows7 64bit. I use Compaq Visual Fortran Professional Edition 6.50, and Ansys CFX 13.0. When I did the tutorial 19(air conditioning simulation), input the Command ! system ("cfx5mkext TStat_Control.F") ==0 or die "cfx5mkext failed"; But the system appears:
ERROR
CCL parser failed with message:
Perl Syntax errors detected:
syntax error at (eval 75) line 2, near ""cfx5mkext failed"
$cclmain:2"
And I tried another method: open "Command Line" (under Tools in CFX-10.0 Launcher) and type:
but there is another problem, the system appears:
A fatal error has occurred in cfx5mkext:
The compiler command "ifort" could not be found. Please ensure that the compiler is on your PATH and try again.
I don’t know what is wrong. I will be grateful if someone tell me how to deal with it. Thank you for your attention.
shenlan05 is offline   Reply With Quote
cfx13.0, fortran compiler, tutorial 17
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 02:39
Fortran Compiler and example Young CFX 1 March 22, 2011 23:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
