Monitor *.out File if ran in terminal instead of WB |
July 6, 2012, 10:24 |
Monitor *.out File if ran in terminal instead of WB on a Linux Cluster
Rep Power: 14 |
I m running my calculation on a linux cluster which just has a terminal interface, via cfx5solve command. I would like to monitor the *.out file of my running simulation, to be able to observe the residuals and monitor points. Is there any build in command to do that with Ansys? Last edited by peterputer; July 6, 2012 at 12:05. |
July 7, 2012, 14:31 |
Rep Power: 14 |
i figured how to save the residuals out of a .res fil via cfx5mondata, but thats not exactly what i need since then i can just monitor the residuals after the run and not online which will just be possible with the *.out file.
July 8, 2012, 08:42 |
Rep Power: 144 |
Why can't you just look at the out file with a text browser. Use "cat" if you have to, or "tail" if you just want to see the last bit.
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
