July 5, 2012, 11:43 |
Custom Fluids (Hydraulic Oil)
John Smith
Hi CFD fans/experts,
Firstly I really appreciate any help at all as I've been through many ANSYS CFD customer portal tutorials, forum posts etc. but am still struggling to find a solution I am attempting to model cavitation of hydraulic fluids through a pipe orifice restriction. I am trying to simulate water-glycol (40% water content) in the CFD-pre material designer. I only know its viscosity, density, operating temperature (and %diol polymers in fluid, not sure if relevant?). I am wondering if to model the fluid as a fixed composite mixture or pure substance. If doing it as a pure substance do I do a multiphase with water vapour (in the assumption that it has a higher vapour pressure and hence will cavitate out before the glycol itself). In doing it as a fixed composite, do I set the child materials as water and glycol (don't know what type though)? however I only know the combined viscosity and density; and what is the mass fraction in this case? Are mixture properties okay to not utilise if unknown? or should I attempt (as fluid properties obtained from an experimental report) to find them online? Thanks in advance, any assistance would be much appreciated! Regards, Sam |
July 5, 2012, 18:27 |
Rep Power: 144 |
The CFX tutorials has an example on how to set up cavitation models.
I would start this model using the simple bulk material properties, as per the example. I would more complex than that if you have a clear reason to do so - do you have a good reason why bulk properties would not be adequate? |
July 5, 2012, 22:03 |
#3 | |
John Smith
Assuming by bulk material properties you mean a pure substance model (for the water-glycol), and create multiphase fluid with this liquid and vapor (as seen in hydrofoil cavitation tutorial?) ? In doing this do I just use the water vapor provided, even though I'm using a water-glycol fluid? Thanks again mate! Sam |
July 6, 2012, 02:04 |
Rep Power: 144 |
Yes, by bulk properties I mean simply a fluid with a density, viscosity and vapour pressure representative of the true water-glycol mixture.
Hydraulic jump | The King | OpenFOAM | 5 | June 18, 2023 07:55 |
oil aeration problem | wprostaff | FLUENT | 0 | July 19, 2011 15:41 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 10:58 |
Lubricant oil, two phase flow | Rikio | CFX | 0 | December 30, 2008 21:08 |
VOF Convergence Problems for Accelerating Oil Pans | A Witry | FLUENT | 6 | June 21, 2001 22:45 |
