how to creat a cone plane with ANSYS 14 CFD-Post |
June 27, 2012, 05:32 |
Lars Wein
Rep Power: 14 |
Dear all,
i try to analyse the flow around the leading edge of a radialcompressor. I want to creat a plane parallel to blade leading edge, exactly in front of the impeller inlet. The problem is that the blade leading edge ist not just radial but backswept in axial flow direction (not backswept in circumferential direction) so the parallel plane has to be a cone. Does somebody know how to creat such a cone plane? I´m grateful for any help. |
June 27, 2012, 06:26 |
Lars Wein
Rep Power: 14 |
I have found the solution by myself.
Its possible to creat a cone plane by inserting a "surface of revolution" mit the method "cone". |
June 27, 2012, 13:44 |
Rep Power: 20 |
be careful using the surface of revolution. I believe v14 still does not trim to the domain (reported this issue way back in v10). If your surface is outside the domain you will get incorrect answers. perform a plot of pressure or velocity on this surface of revolution to do a check.
June 27, 2012, 14:08 |
#4 | |
Peter Galimutti
Rep Power: 14 |
July 2, 2012, 04:15 |
Lars Wein
Rep Power: 14 |
I have try to work with the turbo mode but i am not able to initialize the compoments. Every time i try to initialize the components automatically/manually i get the error massage "can not initialize component "impeller" in domain "impeller" ".
July 6, 2012, 00:38 |
Peter Galimutti
Rep Power: 14 |
Do you have any solid domains? if you have just create a CFD Result component in the WB or Stand alone mode and import the results file.
ANSYS CFX with Remeshing in ICEM CFD | adeban | CFX | 21 | March 29, 2021 07:06 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
[ANSYS Meshing] Can ANSYS ICEM CFD produce quadratic hexa? | a79755172 | ANSYS Meshing & Geometry | 4 | May 24, 2015 05:56 |
User CEL Function and CFD Post | chastain | CFX | 4 | September 24, 2013 14:58 |
Ansys Workbanch or Ansys CFD | Merkur | CFX | 3 | June 14, 2006 23:44 |
