Mixture and Decay of a tracer in a Water Tank
Old   June 23, 2012, 11:14
Default Mixture and Decay of a tracer in a Water Tank
Jeffrey
Jeffrey1992 is on a distinguished road
Hello
I have a problem that i cannot answer yet.
My simulation is a water tank, circular, with Diameter of 10m and a inlet at a center-bottom, with diameter of 0.125m.
There is a mixture of water+tracer entering at inlet, with concentration of 3mg/l. (MixtureInlet)
But, in the water tank, there is another mixture of water+tracer, with a concentration of 4mg/l. (MixtureInside)
Initially, the water lever of the mixture that was alredy in the tank was 9,85m (my tank has 10m high), the water rises until 10m, and then, water goes out until the water level is 3,75m.
The two mixtures will mix, and i will analyse the decay of the tracer with time.
My problem is, the mass fraction of inlet mixture is constant,so, I created a mixture fixed values (Mass fraction of tracer = 2x10^-6).
The mixture INSIDE the tank will mix and decay, so, i created a mixture with variable values.
The Mass fraction, initialy at the tank, before entering any water, is 3x10^-6.
So, i will create a equation that simulates the decay.
But, for that , i will use C= Co. e^-kt
I am trying now, to put the initial value of mass fraction of mixture in tank, 3x10^-6, PLUS the mass fraction of water entering in the water tank.
But it is not working ;/
I tried (Tracer.MixtureInlet.Volume Fraction + 3x10^-6).e^-kt, but it is not working.
Any ideas?
Jeffrey1992 is offline   Reply With Quote
Old   June 24, 2012, 08:49
I do not completely understand your question - do you want the mass fraction of the incoming material to decay over time?
This sounds straight forward. Please post the output file which shows the error.
Old   July 27, 2012, 14:31
Felggv's Avatar
Felipe Gobbi
Felggv is on a distinguished road
First of all, are you familiar with the CEL language? Do you know the variables you're allowed to use? Do you know how to write them properly?
Shouldn't you use Mass Fraction instead of Volume Fraction?
Describe how your materials are set! Do you have water + tracer as a variable composition mixture? Is water set as constraint?
Give us more details of how did you set your parameters, so help will come easier.
Good luck,
Felipe.
Felggv is offline   Reply With Quote
cfd, decay, mixture and liquid, tracer
