June 20, 2012, 17:25 |
Help with interface
Paulo
Rep Power: 15 |
Hi, i'm doing a Transient simulation of a rotational solid enclosure by fluid. I configured the Solid Domain Motion to "Rotating" and the Domain interface to "Transient Rotor Stator"( with none pitch and CGI mesh connection). Also in Interface of fluid side I settled wall velocity relative to Mesh motion and Wall velocity by the angular velocity of solid domain. But, when in Post Solver the Interface of fluid side stay fixed, don't move as Interface of solid side . What i do to it move together in each timestep?
June 20, 2012, 17:36 |
Edmund Singer P.E.
Rep Power: 21 |
In Post make sure you are plotting in the stationary frame.
June 20, 2012, 17:49 |
Paulo
Rep Power: 15 |
Nope, i changed the timesteps many times and only solid side rotate. Also the streamlines cross the solid side. I don't know if is right but i didn't put mesh deformation to solid domain neither rotate in fluid domain.
June 21, 2012, 22:28 |
Paulo
Rep Power: 15 |
anyone know what's wrong in this model?
June 22, 2012, 02:39 |
Rep Power: 144 |
Is this a CHT simulation? What version of CFX?
June 22, 2012, 02:48 |
Paulo
Rep Power: 15 |
June 22, 2012, 03:58 |
Rep Power: 144 |
Rotating solid domains are not supported in V12. This feature was added in V14.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
