Supersonic CD nozzle, goes supersonic but not at the throat.
Old   June 12, 2012, 17:09
Default Supersonic CD nozzle, goes supersonic but not at the throat.
Max
windmill is on a distinguished road
Hello all
I'm modelling a wind tunnel which has a converging-diverging nozzle upstream of the test section. At the moment, the flow almost reaches the target of Mach 2, but what really stumps me is that it becomes sonic not at the throat but a couple of cm downstream.
I've attached some screenshots, as well as the report from CFX-post. If anyone has any ideas I would be grateful for your support.
Thanks
Max
windmill is offline   Reply With Quote
Old   June 12, 2012, 19:23
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i think you need a more refined mesh near the wall. can we take a look at your mesh
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 12, 2012, 20:48
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   June 13, 2012, 06:38
Max
Here is my mesh. I didn't do anything fancy; just imported my geometry and hit "generate mesh".
I did try improving the mesh for the throat area (see edited_mesh), but got a zero divide error in the first iteration (even with a ridiculously small timestep). That being said, I wasn't entirely sure what I was doing when I redid the mesh and just went with the first improvement I got. I'm currently trying to refine the mesh, keeping the quadrilateral elements. I'm also going to set the RMS residual to below 1e-05.
Old   June 13, 2012, 06:46
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Thats not the good idea for supersonic simulation. Dont make any fancy mesh, but at least resolve it in stream wise, radially and boundary layer. Specially you need good refinement in the throat and downstream.
Far is offline   Reply With Quote
Old   June 13, 2012, 08:44
Max
I don't quite understand what you mean there. Could you expand on that a bit please?
Old   June 13, 2012, 10:10
diamondx's Avatar
Ghazlani M. Ali
due to viscosity, velocity is always equal to zero a the wall (boundary layer), but not like in you picture.that layer should be very small. the more you get to the center of your pipe, the velocity get higher. in order to catch that boundary layer, you need a good resolution near to wall, you have to refine. how about an hexa mesh, you geometry is not that difficult
Regards,
Ali
Old   June 13, 2012, 17:20
Max
I tried a hexa mesh (or as close as it would give me) and the boundary layer was doing strange things. I went back to a quad mesh and made it as refined as it would let me without breaking/stopping due to license restricions (5mm - attached).
Now I'm getting close to a M2.5 shock in the tunnel, which is NOT supposed to be happening. I'm not sure what to do on the physics side. Setting a supersonic outlet doesn't work, putting a pressure on the inlet (as opposed to normal velocity which I'm doing now) doesn't work.....
Old   June 13, 2012, 23:52
Far
Sijal
try ICEM CFD HEXA
Old   June 14, 2012, 16:21
Far
Sijal
we can help you out to get the decent mesh
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 01:25
some questions for supersonic channel nozzle goldenland FLUENT 2 November 4, 2007 22:18
Convergence Problem Supersonic Flow Laval Nozzle Tobias CFX 3 December 7, 2005 02:23
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
Small Supersonic Nozzle Paal Main CFD Forum 3 November 25, 2003 05:59
