February 4, 2019, 17:25 |
#101 |
Rep Power: 144 |
By definition a mesh sensitivity analysis is running the simulation on different meshes. So you cannot avoid running many different meshes.
Here are some useful references for basic analyses: https://caeai.com/blog/how-do-i-know...sh-good-enough https://www.computationalfluiddynami...pendent-study/ More advanced techniques are here: https://journaltool.asme.org/Templat...umAccuracy.pdf The textbook "Computational Fluid Dynamics" by Roache, and The Richardson Extrapolation technique (look it up)
February 5, 2019, 06:36 |
#102 |
Rep Power: 8 |
Thank you Mr. Horrocks, that really helps! A couple more questions:
1. So then my project schematic would look like the attached picture? 2. I'M using a student license and no Adaptive Sizing. I have a number of local refinements defined. So how do I globally refine the mesh? There seems to be no 'Refinement' option in the global controls when my adaptive sizing is off. Thanks a lot for your time! |
February 5, 2019, 18:00 |
#103 |
Rep Power: 144 |
You schematic looks OK.
When I do mesh refinement if possible I halve the length of all edge length definitions, both global parameters and any local refinement. If that is not possible then you halve the element edge lengths in the critical areas but this does compromise the analysis somewhat.
February 7, 2019, 04:46 |
#104 |
Rep Power: 8 |
Great, Thanks a lot!
Converging Diverging Nozzle in OpenFOAM | danishdude | OpenFOAM Running, Solving & CFD | 1 | September 15, 2012 01:12 |
Wall scale not converging | arunraj | CFX | 1 | October 3, 2011 18:52 |
transient converging, but not steady | PHS- | FLUENT | 5 | July 25, 2011 15:25 |
solution not converging for fine mesh.. | saurabh.deshpande88 | FLUENT | 2 | February 2, 2010 11:23 |
Continuity residual not converging | Chinenye Excel Ogugbue | FLUENT | 0 | April 28, 2008 03:27 |
