June 10, 2012, 14:46 |
advice on wind turbine simulation?
Rep Power: 14 |
Hello CFD community,
i am a bit clueless with my wind turbine simulation which i have to do for a universityproject... After reading a lot in the Ansys documentation and on the internet (and this forum in particularly) i created a simlation as follows (see also first picture): - 2 domains, one stationary and one rotational - the blade is cut out of the inner domain and the generated faces are defined as wall - inner domain is rotating to get a realistic airvelocity at the rotating blade (increasing to the tip) - domains are connected with a frozen rotor interface - the rotational periodicity is generated as a rotational periodicity interface The results i get are a bit confusing and i guess that i made a general designmistake. If you look at the results (picture 2 and 3) you can notice a very abrupt change of the velocity between the two domains. I would have expected a steady distribution in the whole designspace. Can you give me an advice how i have to change the flow analysis to get a realistic solution? My first guess is that i made a mistake in geometry. My blade is also rotating, because it is a part of the inner domain. Actually i wanted to create a stationary blade and a rotating domain round this airfoil to get the velocitydistribution. Should i use 2 domains and a rigid body (blade) which overlaps the inner domain??! I tried this approach, but i couldn't create a mesh with a prism layer because of the overlap of the domain and blade... Your help is apprecited a lot! |
June 10, 2012, 18:53 |
Try to plot the velocity in stn frame. This variable (velocity) is the relative velocity caused by the rotation of the rotating domain relative to a stationary observer.
-- Kyriakos Vafiadis Mechanical Engineer, PhD candidate |
June 11, 2012, 04:31 |
Rep Power: 14 |
Ahh! Thanks, that explains a lot!
simulation on wind turbine... | qiba123 | Fidelity CFD | 1 | May 27, 2012 21:47 |
2D Simulation of Savonius Wind Turbine | ravindersingh | FLUENT | 4 | December 9, 2011 13:00 |
3D simulation of wind turbine in Yaw wind(in a lateral wind) | mohammad | Main CFD Forum | 0 | December 28, 2010 03:26 |
Wind Turbine simulation | Bharat | FLUENT | 0 | August 18, 2005 04:38 |
wind turbine aerodynamics | bharat | Main CFD Forum | 1 | November 29, 2004 11:26 |
