Discontinuity at water level in stratified 2 phase flow
Old   June 13, 2012, 09:15
Simply go to the domain tab and define an initial condition. Or use the global initialisation tab.
If you just want to quickly evolve the flow to a pseudo-steady state flow then use your best steady state run as an intial condition.
Old   June 13, 2012, 09:33
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
I not understand how to set an initial condition for the domain? I went to default domain then activate initialisation but still get the same warning?
kbaker is offline   Reply With Quote
Old   June 13, 2012, 09:36
Have a look at some of the CFX tutorials which cover a transient simulation. See how they set up the initial conditions.
Old   June 13, 2012, 09:52
kbaker's Avatar
Khalid Baker
well if you read the warning message it as below:
Transient analyses require that initial conditions are specified unless an Initial Values file is specified at run-time
I am wondered where the initial values file I did not create any values file during the simulation? I also create an intermediate file for the results from output control but warning still exist and the run cannot start?
Old   June 14, 2012, 08:37
kbaker's Avatar
Khalid Baker
In order I transform the problem to unsteady I aware that I need to transform the analysis type to transient? Is there any steps I need to follow before applying the previous step? I check all the steps in transient tutorials nothing mentioned and I never apply it but I still cannot run my case file and the previous warning message still exist?
two phase slug flow Justion FLUENT 4 June 5, 2014 11:47
Two Phase Flow Problem miner15kick CFX 5 October 28, 2010 19:03
Two phase T-junction pipe flow Viscous model Kortels FLUENT 0 September 10, 2010 07:18
Stratified Oil-water Flow simulation Mijail FLUENT 2 May 18, 2009 21:20
How to set volume fraction in two phase flow Kamel FLUENT 2 March 23, 2007 01:06
