May 30, 2012, 07:15 |
Conjugate heat transfer
Alireza
Rep Power: 15 |
Hi Friends
I'm a Ph.D. student majoring in mechanical engineering, working on “Unsteady Conjugate Heat Transfer in reacting flow”. I faced some questions about CFX. I’d be so thankful if you could help me. 1. Does CFX solve this problem (Unsteady Conjugate Heat Transfer in reacting flow)? 2. Which algorithms does CFX use for conjugate heat transfer? With Kind Regards |
May 30, 2012, 08:28 |
Rep Power: 144 |
1. Yes, CFX can solve it.
2. The solid domain is directly coupled to the fluid domain. If the flow is laminar then the temperature is coupled across both domains directly, if turbulent wall functions then coupled through the wall functions. |
May 30, 2012, 08:39 |
Alireza
Rep Power: 15 |
thank you so much
but I nead to slove a reacting flow for example when we have a combustion in a combustor, there is a intensive temprature gradient this issue will be caused bad convergency in couple boundary what is your idea about it? |
May 30, 2012, 08:42 |
Rep Power: 144 |
Yes, that will make convergence more difficult and accuracy a challenge. But CFX has all the models required to make it work, you just need to apply them correctly.
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 07:33 |
Conjugate heat transfer | kiteguru | CFX | 2 | January 9, 2012 16:57 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
