If statement question
Old   May 23, 2012, 08:01
Default If statement question
mariam.sara is on a distinguished road
Hello I am tried to wright if statement to set velocities of two fluids (one at the bottom of the pipe and the other on the upper part) I tried use CEL expression and I use in it If expression to distribute the velocity between the phases as below:
if(y>0.01 [m],if(y<=0.01 [m],12.5 [m s^-1],0.0066 [m s^-1]),0 [m s^-1])
where y vertical distance
0.01 m is the free surface level
knowing that the velocities at walls are zero (no slip condition).
when I try test the expression above before run in cfx-pre it gives zero velocity everywhere along y direction so what the problem? may somebody tell me? is the expression incorrect? I read at the documentations about IF statement but not find similar example to my case?
mariam.sara is offline   Reply With Quote
Old   May 23, 2012, 12:34
Lance
Lance is on a distinguished road
if(cond_expr,true_expr,false_expr)
Do you want 12.5 m/s above 0.01 m and 0.0066 m/s below 0.01?
if(y>0.01 [m],12.5 [m s^-1],0.0066 [m s^-1])
Lance is offline   Reply With Quote
Old   May 23, 2012, 15:17
Yes when y>0.01 m velocity is 12.5 m/s
But when y<=0.01 m velocity is 0.0066 m/s
When y=0 & y=0.0985 m (at lower and upper walls respectively) velocity is 0 m/s
with the above conditions how the expression will be?
Thanks
Originally Posted by Lance View Post
Old   May 24, 2012, 03:33
Lance
The expression I gave you will work. At the walls the velocity will be zero unless you have defined a free-slip wall.
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 21:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
Philosophical CFD question Richard Howe Main CFD Forum 14 June 17, 2001 15:41
