May 22, 2012, 18:54 |
two-pipe heat exchanger simulation
laleh
I want to simulate a two-pipe heat exchanger by CFX. The diameter of inner pipe changes sinusoidally. The main purpose is to optimize heat transfer coefficient to get the least pressure drop by changing the inner tube. The question is how can I get the geometry of the inner tube so that it can be modified in the CFX? |
May 22, 2012, 19:25 |
Rep Power: 144 |
This sounds like a parametric model in workbench. Have a look at the workbench tutorials. You might also want to look at DesignExplorer as an add-on to workbench.
Heat Exchanger Model | sak2129 | FLUENT | 3 | September 26, 2017 01:29 |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 06:33 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
the simulation of the heat pipe | Crystal | FLUENT | 0 | June 21, 2008 10:38 |
