Can someone explain me this error?
Old   May 21, 2012, 12:24
Default Can someone explain me this error?
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hi when I run my simulation the error below appeared after nearly 15 iterations:
A wall has been placed at portion(s) of an OUTLET boundary condition (at 100.0% of the faces, 100.0% of the area) to prevent fluid from flowing into the domain.
The boundary condition name is: outflow.
The fluid name is: Water.
If this situation persists, consider switching
to an Opening type boundary condition instead.
may somebody tell me what its reason?
Thanks
kbaker
kbaker is offline   Reply With Quote
Old   May 21, 2012, 12:41
Lance
Lance is on a distinguished road
Use the forum search function, this is one of the most common questions asked...
Lance is offline   Reply With Quote
Old   May 21, 2012, 13:00
kbaker's Avatar
Khalid Baker
ِAs I saw from the other posts about this error some suggests to solve the problem with moving the exit boundary further away from the inlet to prevent reverse flows I need to say my pipe length is 25 m and diameter is 98.5 mm so I think the inlet is located in a far distance from the outlet ? I am right or I need really to make the pipe longer?
Old   May 21, 2012, 19:36
Your warning is saying 100% of the outlet has backflow. In this case the problem is more fundamental as none of the outlet is working as expected. You need to look into why the entire outlet wants to flow backwards.
Old   May 21, 2012, 19:41
Default Hi
Danial
Danial Q is on a distinguished road
Try this, it might work for you;
Expert parameters > Discretization > Miscellaneous > Build artifical wall > set to " f ". By default its "t". F will not build any artifical wall and try to reduce your time steps also.
cheers
Danial Q is offline   Reply With Quote
Old   May 21, 2012, 19:43
Sorry Danial, this is a bad idea. Something is wrong with the simulation and that is making the flow want to go backwards. Rather than letting it go backwards you should fix the root cause of the problem, and make the flow want to go forwards.
Old   May 22, 2012, 11:38
piyo is on a distinguished road
In CFX, when the outlet condition is used, the solver will build an artifitial at outflow position to allow for outflow but prevent backflow. As been recommanded, this setting should not be switched off in expert parameters in most time. If your position has backflow in real case, you'd better use opening condition, and of course, requiring more time to converge.
piyo is offline   Reply With Quote
Old   May 22, 2012, 12:00
kbaker's Avatar
Khalid Baker
The message disappeared when I use double precision and switch to segregated treatment for the volume fraction coupling and reduce time step to 0.001 s and I still use outlet boundary but the results shows higher liquid level which I define it at inlet and outlet as the same with value 5.5 mm (where pipe diameter is 98.5 mm) and it seems more higher than expected with unknown reason?
Old   May 22, 2012, 20:07
So it seems the outlet back flow was due to problems converging. This confirms you should fix the root cause of the problem and not just allow back flow to occur.
Your question about accuracy is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
