May 20, 2012, 00:42 |
ANSYS 13 Multifield,
adminCAE
Rep Power: 16 |
Hi to all,
I have a question referring to study fluid flow and thermal using CFX from ANSYS 13. How I observe, in last period ANSYS put very much accent on Workbench module. I am using ANSYS MAPDL. So, my question is : the version of ANSYS 13 can made coupled simulation (two ways simulation or MFX) using CFX and ANSYS MAPDL, or only using Workbench module? because this type of coupled study in the past (old version of ANSYS) it was possible. Thank you in advance for advice and answer. Best regards.
Mess with the best die like the rest ... ANSYS is the best !!! |
May 20, 2012, 07:29 |
Rep Power: 143 |
Yes, it is possible. Workbench justs generates the APDL for the simualtion, so I guess if you used the same APDL you can do it without workbench. I would run a test MFX simulation and have a look at the APDL and command lines it uses to do it.
May 26, 2012, 09:32 |
Peter Galimutti
Rep Power: 14 |
Yes, you don't need work bench for multi-filed simulation. It's just an interface bringing all Ansys programs under one roof!
ps: I believe if you want to do multifield simulation with CFX as the flow solver, you may not be able to do it MAPDL itself. You just create a data file in MAPDL with b.c's & coupling conditions etc, which will be read into CFX. CFX does the rest of the interactive analysis. If you want to do entire analysis in MAPDL, Flotran does the flow solving. |
Command Line Run for ANSYS | Liaquat | ANSYS | 11 | April 19, 2018 09:49 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 09:16 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 12:59 |
FSI Simulation unsing ANSYS Multifield | k_buz | CFX | 2 | April 6, 2009 17:40 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
