transient spray modelling
Old   May 14, 2012, 04:20
Default transient spray modelling
anand
anand3984 is on a distinguished road
hi
I am beginner in spray modelling. I am trying to solve transient spray injected in still air using CFX-11. i have created particle injection region and injecting the droplet with blob method. also trying to simulate secondary breakup with TAB model. But when I am specifying the number rate (number of position) to any value like 300/s or 3000/s i am getting only 1 droplet entered in domain (solver panel) also the initial iteration number for which it should not inject the droplet, i am specifying 1000, even it is injecting from first time step.
can any body help me out how to control this droplet number in transient calculations
anand3984 is offline   Reply With Quote
Old   May 16, 2012, 05:45
Timon is on a distinguished road
If you're doing transient particle tracking and you're specifying the droplet injection rate (in droplets per second), then the amount of droplet injected per timestep are of course dependent on your time step.
E.g. if you're timestep is (1/300) s and you're injecting 300 droplets per second, then you would see 1 droplet being introduced into your domain every timestep.
Timon is offline   Reply With Quote
Old   May 23, 2012, 07:03
Default spray modelling
anand
Thanx for your reply.......i got it.
Can we model Collision and Colescence in lagrangian framework for modelling the spray in CFX-11
transient spray modeliing
Reference on atomization and spray modelling alberto OpenFOAM Running, Solving & CFD 1 September 14, 2012 14:14
CFD spray modelling Kumar FLUENT 1 September 14, 2012 13:56
transient result in spray reactor with swirl flow glenn creten Main CFD Forum 1 August 14, 2012 06:10
HELP! post processing for spray modelling hamish888 FLUENT 1 August 2, 2012 11:21
Porous jump modelling: steady vs transient egge24 FLUENT 2 January 20, 2012 05:05
