May 2, 2012, 05:24 |
number of nodes in solid domain
Rep Power: 15 |
I want to know what decides the number and distribution of nodes in a solid domain in a CHT problem.(Like we have y+ for a fluid domain). Thanks |
May 2, 2012, 19:17 |
Rep Power: 144 |
It is determined by your mesh, obviously.
But I think you are asking what should you consider as you mesh a solid body for CHT simulation. In a solid the only thing you are resolving is the temperature gradient. In steady state simulations this is usually much more gentle than any flow gradient, meaning a much coarse mesh is acceptable. In transient simulations you need to resolve the temperature gradient in time and space - if you are trying to resolve a very fast temperature transient then you will need a fine mesh to resolve it. In the unusual case of a transient simulation with a fast temperature gradient inflation layers may be appropriate. Otherwise, a coarser mesh is usually fine as it simply has to resolve the temperature gradients. But as ever, check it with a mesh sensitivity study to check that it is OK. |
May 2, 2012, 22:18 |
Rep Power: 15 |
Thanks Glenn
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
heat conducting in a solid domain | Rogerio Fernandes Brito | Fidelity CFD | 0 | March 18, 2008 18:24 |
THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY | CARL | CFX | 1 | June 9, 2006 17:44 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
