Rep Power: 15 ![]() |
I am trying to simulate a simple CHT problem. I give a constant heat flux the base plate(with certain thickness) and a fin is attached to the base plate(as a integral part of base). Both are made of aluminium. Air flows over the fin. Interfaces with conservative interface flux has been defined at domain interfaces. I get a domain imbalance for H-energy for air as ~ 3% !!! and T-energy as ~0.3% .(residuals have converged) Kindly suggest some ways to improve my soln. asap. Thanks |
Rep Power: 21 ![]() |
Residuals are not a measure of global conservation. Keep running until the imbalances are reasonable (or use the Conservation Target control).
Rep Power: 144 ![]() ![]() ![]() ![]() |
As stumpy says, you need to include imbalances in the convergence definition. CHT is the key example where imbalances are required to gauge convergence as residuals do not pick up the global imbalance.
If steady state, you probably alos need to use some solid time scale factor as well. This greatly accelerates convergence in CHT simulations. |
Thanks stumpy and Glenn.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 11:16 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
Domain imbalance and convergence | colen | CFX | 1 | December 8, 2010 13:56 |
CHT Problem - Domain Imbalance | Parthipan | CFX | 5 | September 11, 2007 10:13 |
