How to apply pressure 6.2psi on the upper spinnig head
Old   April 26, 2012, 20:25
Default How to apply pressure 6.2psi on the upper spinnig head
June
msormania is on a distinguished road
I am running CFX transient incompressible NS eqns with multi-phase flow (Water/Air) in the immersed solids (Upper small head and lower big plate). Both head and big plate are spinning in the same direction with different angular speed and at fixed different centers.
Firstly, I could not find an option to put pressure 6.2psi down to the lower big plate for pulling the pressure distribution with and without pressure on the head. Without pressure is easy because just we give 0 pressure on the boundary but, with pressure on the head, I could not find how to apply pressure down to the big head.
How can I apply pressure just on the head part?
Secondly, I found the wrong output direction which is bouncing back to inside of the wall, which is problematic.
What should I do for getting rid of the wrong output in the wall part?
Thank you very much,
Best regards
msormania
msormania is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
which B.C. i should apply for this problem? raivish CFX 0 January 6, 2006 09:47
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
