April 25, 2012, 15:12 |
condensate film on a wall
Rep Power: 16 |
I'm trying to simulate defogging on simple cabinet model like windshield aplication. In CFX, is it possible to define a certain thickness of uniformly distributed water condensate film on a wall as an initial condition? I would like to see the effect of defroster nozzle geometry on condansate film evaporation. Continuous phase: gas mixture (air ideal gas and h2o<vapor>) Version: 12.1 thanks |
April 25, 2012, 20:29 |
Rep Power: 144 |
You might be able to adapt the wall film model (developed for IC engine fuel applications) to this. Otherwise you might be able to use an additional variable. Both of these options are tricky and will require development.
April 26, 2012, 02:30 |
Rep Power: 16 |
Thank you Glenn,
So, I should try to particle spray over wall to form a film at first, am I wrong? |
April 26, 2012, 07:13 |
Rep Power: 144 |
I have never used this model so cannot tell you how to use it. Hopefully you can set an initial condition but I am not sure.
April 26, 2012, 09:01 |
Rep Power: 16 |
Thank you very much Glenn,
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Very technical question about solving wall boundary layer ... | jlb001 | FLUENT | 6 | December 27, 2014 06:56 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
Wall functions? | Pr | Main CFD Forum | 7 | April 8, 2004 07:15 |
Quick Question - Wall Function | D.Tandra | Main CFD Forum | 2 | March 16, 2004 05:29 |
