Conditional Expression in CFX Pre
Old   May 28, 2012, 03:04
Default Hi Lance
  #81
Danial
Danial Q is on a distinguished road
yes it does, >= can work as greater than or equal to.....what i am confused about is how to define a range if(1725.5[K]<=T<=1726.5[K],
will it work if i do it like u showed above??T<1726.5 and T > 1725.5[K]
is AND allowed in syntax FOR EXPRESSION by cfx.?? or i should use &&
Thanks
Danial Q is offline   Reply With Quote
Old   May 28, 2012, 04:14
Lance
Lance is on a distinguished road
You misunderstood. You cannot use expressions like 234 <= T <= 345 as it is not a valid format. I think & or && might work, see the documentation?
Why not use a 1D user function if you only want to assign temperature dependent properties?
Lance is offline   Reply With Quote
Old   May 28, 2012, 04:37
Default HI Lance
  #83
Danial
Thanks i got ur point but a bit late and did it. it worked. I din t use 1D interpolation because my problem involves latent heat in it so ,it was not gonna work, itried it earlier.
Thanks again
Old   May 28, 2012, 04:49
Default Hi LANCE
  #84
Danial
Q# if we have two domains (fluid and solid) and they are interconnected with interface. For heat released by fluid should be necessarily defined as a "SOUrce" by creating subdomain in solid
OR
due to presence of interface, it will be transfered automatically to the solid domain which is at very low temp regrading fluid domain????
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 05:56
Defining a domain in CFX Pre ashtonJ CFX 1 June 13, 2011 03:34
different CFX Pre and Post mesh region mactech001 CFX 9 April 11, 2010 22:08
Problems with adding two meshes together in CFX Pre peterputer1 CFX 2 September 23, 2009 09:08
CFX Pre - TGrid Vivek Vasudevan CFX 2 March 20, 2007 07:31
