Home > Forums > CFD Online Community > CFD-Wiki
Writting equations on cfd-online.com
Old   September 9, 2006, 12:13
Default Writting equations on cfd-online.com
Guillermo Marraco
How do you write equations on cfd-wiki?
Is there a free tool for writting the pages off-line?
Old   September 10, 2006, 06:44
Default Re: Writting equations on cfd-online.com
Jonas Larsson
CFD-Wiki uses a subset of LaTeX to typeset equations. LaTeX uses normal ascii formatting to describe mathematical formats, so the source text can be written in any text editor. LaTeX is a very common format in the academic world and is used by many researchers. To see how a particular formula in CFD-Wiki is written just click on "Edit" to see how the actual text looks.
For some more introduction material on CFD-Wiki equations you can look at for example:
http://en.wikipedia.org/wiki/Help:Formula
If you want to write and see equations off-line you need access to a computer with LaTeX installed. On Windows the most common distribution is MikTex (http://www.miktex.org/) and on Linux/Unix the most common distribution is TeTex (http://www.tug.org/tetex/). There is also a new project which might be better to use, I haven't tried it yet. It is called Tex Live (http://www.tug.org/texlive/).
Old   September 11, 2006, 19:12
Default ReĀ²: Writting equations on cfd-online.com
Guillermo Marraco
Thanks.
I are downloading MikTex.
I want to write the things I have needed. They are simply, but have little atention from the cfd comunity.
I gonna write it before I forget "the times that they were not obvious"...
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
Writting own files calculated value during the run in Parallel anne OpenFOAM Running, Solving & CFD 12 May 27, 2008 16:53
writting equation msdev fortran editor Bounecer Main CFD Forum 0 January 20, 2008 02:32
Text Command for writting a pathline file Laurence Wallian FLUENT 0 September 29, 2005 06:56
want online job atia anjum Main CFD Forum 0 September 7, 2003 02:38
