Home > Forums > CFD Online Community > CFD-Wiki
Image uploading
Old   September 14, 2005, 19:30
Default Image uploading
zxaar
There are lot of images we will be uploading, we might have to fix some rules to name them while uploading, for example, when i upload any image, i used
nm for numerical method, what others think???
Old   September 14, 2005, 19:37
Default Re: Image uploading
Michail
I agree.
Format:
TT_Section_theme.xxx
TT - topic name
Section - Section name
theme - name of the conrete image
Old   September 15, 2005, 00:04
Praveen. C
Sounds like a good idea.
Old   September 15, 2005, 05:59
Jonas Larsson
Sounds good
Old   September 15, 2005, 13:58
jasond
One question - I have already uploaded a couple of images (for the lid-driven cavity article), so how would I change the files names for them to fit the format. I am failing to figure out how to do this in the wiki docs.
Jason
Old   September 15, 2005, 16:22
Jonas Larsson
I don't think that there is an easy way for you to rename an already uploaded image. But you can just upload the image again, give it the desired new name, and then remove all links to the old image. Then it will become an "orphaned" image and I, or another wiki admin, will regularly clean out orphaned images.
Old   September 15, 2005, 18:36
zxaar
I think you should decide on some format and put it one guide lines so that all the other new editors shall also follow this. And lets decide on some intitial acronyms to decide on images related to certain areas. For example for numerical models i am using
Nm_X for general images related to numeical methods Nm_section_subsection_name. for specific images
So we got to agree upon a set of such intial names for the sections.
ParaView 330 image saving and image copy ma436 OpenFOAM Bugs 1 February 5, 2009 04:13
uploading icem program rageb FLUENT 1 June 25, 2008 11:46
Uploading files Salvador CFD-Wiki 5 December 14, 2005 12:24
About uploading files Jonas Larsson CFD-Wiki 1 September 21, 2005 08:32
Suggestion: uploading CFD examples Ralf Schmidt FLUENT 4 September 3, 2005 20:52
