August 5, 2024, 07:54 |
The rpm of a turbine doesn't converge
Álvaro
Good all, for a work I am doing, I need to determine the rpm of a turbine for a constant wind speed of 3.5 m/s and a constant resistive torque of 15 N-cm. The problem I am encountering with my simulation is that the rpm does not converge to any stationary value, but on the contrary, it does not stop increasing the more simulation time I add. I am currently simulating with a very small interval of 0.05 seconds to prevent the simulation from diverging but I can't find where the problem is and how to address it in order to get the results. If anyone knows how I could try to modify the simulation to get the results I would greatly appreciate it.
August 9, 2024, 01:30 |
#2 | |
shiva kumar
Rep Power: 5 |
Hi let me know if you are still facing the issue, you can connect me at aeroshivakumar@gmail.com
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues | ama294 | ANSYS Meshing & Geometry | 12 | September 29, 2014 14:23 |
Gas turbine in CFX | rahat69 | CFX | 4 | April 12, 2014 00:44 |
OpenFoam 1.6-ext - RPM build errors | preibie | OpenFOAM | 12 | September 8, 2011 04:12 |
turbine Rpm | ahahha | CFX | 4 | December 12, 2010 07:54 |
RPM vs time for a turbine | johnny | FLUENT | 0 | November 10, 2005 05:00 |
