June 8, 2023, 11:07 |
MSMD Battery simulation
Raj
Looking for someone to help me with battery simulation under air cooled condition.
Battery specification: 18650 model Cylindrical Li-ion battery. I am using Ansys 2020R1. Connection: Each pack has 6 cylindrical battery in parallel connection and I need 5 of the packs in series form. The outer case of the battery pack has 5mm semi-circular hole, which is critical for the actual performance. Please look at the documents. I am willing to pay for the work. with case.PNG without case.PNG Actualbattery_6cells.PNG Actual_setup.jpg https://enepaq.com/wp-content/upload...2022-03-24.pdf Last edited by R Grng; June 9, 2023 at 20:56. |
June 11, 2023, 09:53 |
For Outsourcing
Ali Riaz
Rep Power: 10 |
I am a mechanical engineer and have expertise in CFD analysis.
You can contact me at +92-336-8637493 or freelanceengineers007@gmail.com |
June 19, 2023, 23:43 |
Ali Riaz
Rep Power: 10 |
You can contact @ freelanceengineers007@gmail.com for complete analysis of this problem.
June 27, 2023, 00:54 |
shiva kumar
Rep Power: 5 |
Inbox me if you are still looking for battery simulation
you may reach out to me at aeroshivakumar@gmail.com |
July 22, 2023, 01:49 |
OpenFOAM Solution
Rep Power: 5 |
Hi @R_GRNG,
I have industrial experience in developing and simulating battery pack modules. I have experience in opensource codes for same. I have multiple packages available for the required help. Please contact me on abhishek_2k20@protonmail.com if intrested. Click this link to see my rating by my clients: https://www.fiverr.com/abhishek_2k20 Thanks and Regards Abhishek Singh Last edited by abhishekmonu96`; July 22, 2023 at 08:57. |
Battery thermal simulation | CFD10111 | Main CFD Forum | 0 | September 20, 2022 08:52 |
[DesignModeler] A battery simulation, zone definitions | Ahmed Saeed Mansour | ANSYS Meshing & Geometry | 0 | June 6, 2018 11:20 |
Data for Battery cooling simulation | Bharatt | Main CFD Forum | 0 | October 27, 2017 05:06 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
