February 26, 2023, 14:21 |
Applying LES to the case done with K-e
Rep Power: 4 |
I have an article about pollutant dispersion that I regenerated the results. I have the data and geometry and Mesh. I need to apply LES method to the Geometry. this should be done by OpenFoam. can anybody help?
March 5, 2023, 05:46 |
#2 | |
Karim Hassanieh
Rep Power: 10 |
Email : karimhassanieh@gmail.com |
openfoam |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Problem to run flow around a cylinder - LES case | valerio galluzzi | OpenFOAM Pre-Processing | 2 | August 29, 2014 06:05 |
Problem to run flow around a cylinder - LES case | valerio galluzzi | OpenFOAM Pre-Processing | 0 | August 26, 2014 08:47 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 23:16 |
