Home > Forums > General Forums > CFD Freelancers
Converting a UDF from FLUENT 17.2 to FLUENT 2021 R2
Old   July 10, 2022, 10:06
Default Converting a UDF from FLUENT 17.2 to FLUENT 2021 R2
Ohio
herko is on a distinguished road
Hello everyone,
I need some help converting some code that I have for ANSYS 17.2 to ANSYS 2021 R2. The primary issue that I face is that whenever I try to run the code in anything after ANSYS 18.0, it does not work properly. I have looked at the FLUENT customization manual and the changes that were suggested are not working. This shouldn't be a super complicated job, but I am willing to pay for anyone who can help me fix this issue.
To further describe the job, I am using a discrete phase model and whenever I try to create an injection using the described UDF to initialize the injection, Fluent returns the message:
"The Parcel model is not compatible with the udf-injection-init.
The model will be disabled and the standard parcel release method will be applied." I would like to use the constant-mass parcel release method, but as it is now, Fluent will only let me run the standard parcel release method. I have attached the UDF initialization code and the injection information that I used below. If you need more info, just let me know.
UDF:
DEFINE_DPM_INJECTION_INIT(init_Intelligent,I) /*Init for particles by Intelligent option */
Particle *p;
loop(p,I->p)
PP_USER_REAL(p, 0) = 0.;
PP_USER_REAL(p, 1) = PP_MASS(p) * PP_N(p) ;
PP_USER_REAL(p, 2) = 10.0; /* Intelligent option */
PP_POS(p)[2] = 0.1; /* for check */
Injection Information:
X-pos(m):-2.538
Y-pos(m):0.84
Z-pos(m):3.6576
X-vel(m/s):11.0475
Y-Vel(m/s):-3.6024
Z-vel(m/s):0.89408
Diameter(m):0.0001092
Temperature(K): 283.15
Flow Rate(kg/s):0.0021373
Start Time(s):0
Stop Time(s):4.0909
Drag Law: dynamic drag
Breakup: breakup enabled, TAB model used with y0=0, breakup parcels=2
Injection type: single
Particle type: droplet
Material: water-liquid
Evaporating species: h2o
Stochastic tracking: Discrete random walk model and random eddy lifetime enabled, number of tries = 1, Time-scale constant = 0.15
Parcel release method: constant mass
Parcel mass: 1*10^-6
UDF Initialization: init_intelligent::UDF_UM
herko is offline   Reply With Quote
ansys, discrete phase model, fluent, parcel simulation
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 16:26
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
