June 30, 2022, 03:30 |
Having problems with validating results
PPB
Hello Everyone
I have just started learning SU2 (the latest version) two months back and was trying the replicate the 'Axisymmetric shock wave-boundary layer interaction case given on the NASA turbulence modeling website (https://turbmodels.larc.nasa.gov/axiswblim7_val.html). I have used the grids given on the website. I have attached the CFG file for my simulation below. The simulation runs just fine and has a pretty decent convergence (residual plots attached below (names represent the grid used)) but the results do not match with the ones given on the website (pressure plots attached below for respective grids). Kindly point out any errors that seem to be there and any other changes that I should incorporate. This is my first post on the thread. I apologize for missing out on any forum etiquette. I would be extremely obliged to receive any kind of help. Thank You ####Code for Simulation#### %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % % Case description: Turbulent flow past the ONERA M6 wing % % File Version 5.0.0 "Raven" % % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= RANS % % Specify turbulence model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SA % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % % System of measurements (SI, US) SYSTEM_MEASUREMENTS= SI % % Axisymmetric simulation, only compressible flows (NO, YES) AXISYMMETRIC= NO % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 7.11 % % Angle of attack (degrees, only for compressible flows) AOA= 0 % % Side-slip angle (degrees, only for compressible flows) SIDESLIP_ANGLE= 0.0 % % Init option to choose between Reynolds (default) or thermodynamics quantities % for initializing the solution (REYNOLDS, TD_CONDITIONS) INIT_OPTION= REYNOLDS % % Free-stream option to choose between density and temperature (default) for % initializing the solution (TEMPERATURE_FS, DENSITY_FS) FREESTREAM_OPTION= TEMPERATURE_FS % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 80 % FREESTREAM_PRESSURE= 550.13 % % Reynolds number (non-dimensional, based on the free-stream values) REYNOLDS_NUMBER= 5706000.00 % % Reynolds length (1 m by default) REYNOLDS_LENGTH= 1 % FREESTREAM_TURB2LAMVISCRATIO= 5.0 % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Different gas model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS) FLUID_MODEL= IDEAL_GAS % GAS_MODEL= AIR-5 % GAS_COMPOSITION= (0.77, 0.23, 0.0, 0.0, 0.0) % % Ratio of specific heats (1.4 default and the value is hardcoded % for the model STANDARD_AIR) GAMMA_VALUE= 1.4 % % Specific gas constant (287.058 J/kg*K default and this value is hardcoded % for the model STANDARD_AIR) GAS_CONSTANT= 287.058 % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= SUTHERLAND % % Sutherland Viscosity Ref (1.716E-5 default value for AIR SI) MU_REF= 1.716E-5 % % Sutherland Temperature Ref (273.15 K default value for AIR SI) MU_T_REF= 273.15 % % Sutherland constant (110.4 default value for AIR SI) SUTHERLAND_CONSTANT= 110.4 % --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------% % % Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL). CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % % Molecular Thermal Conductivity that would be constant (0.0257 by default) THERMAL_CONDUCTIVITY_CONSTANT= 0.0257 % % Laminar Prandtl number (0.72 (air), only for CONSTANT_PRANDTL) PRANDTL_LAM= 0.72 % % Temperature polynomial coefficients (up to quartic) for conductivity. % Format -> Kt(T) : b0 + b1*T + b2*T^2 + b3*T^3 + b4*T^4 KT_POLYCOEFFS= (0.0, 0.0, 0.0, 0.0, 0.0) % % Definition of the turbulent thermal conductivity model for RANS % (CONSTANT_PRANDTL_TURB by default, NONE). TURBULENT_CONDUCTIVITY_MODEL= CONSTANT_PRANDTL_TURB % % Turbulent Prandtl number (0.9 (air), only for CONSTANT_PRANDTL) PRANDTL_TURB= 0.90 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.00 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 1 % % Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE, % FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= DIMENSIONAL % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_ISOTHERMAL= ( isothermal_wall, 311.0 ) % % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( inlet_freestream ) %MARKER_INLET= ( inlet_freestream, 888.8336, 2574482.89513, 1.0, 0.0, 0.0 ) % MARKER_OUTLET= ( outlet, 563.162 ) % % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, % rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, % rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( periodic_start, periodic_end, 0.0, 0.0, 0.0, 359.0, 0.0, 0.0, 0.0, 0.0, 0.0 ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( periodic_start ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( periodic_start ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 0.5 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 0.1, 2.0, 0.1 , 200.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations ITER= 100001 % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver for the implicit (or discrete adjoint) formulation (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (NONE, JACOBI, LINELET) LINEAR_SOLVER_PREC= ILU % % Linear solver ILU preconditioner fill-in level (0 by default) LINEAR_SOLVER_ILU_FILL_IN= 0 % % Min error of the linear solver for the implicit formulation LINEAR_SOLVER_ERROR= 1E-10 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 20 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 0 % % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= AUSM % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) MUSCL_FLOW= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Coefficient for the Venkat's limiter (upwind scheme). A larger values decrease % the extent of limiting, values approaching zero cause % lower-order approximation to the solution (0.05 by default) VENKAT_LIMITER_COEFF= 0.05 % % 2nd and 4th order artificial dissipation coefficients for % the JST method ( 0.5, 0.02 by default ) JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) CONV_FIELD= RESIDUAL % % Start convergence criteria at iteration number CONV_STARTITER= 10 % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -20 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-6 % % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= 81x101_ASWBLI_mesh_3D.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FILENAME= solution_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= CSV % OUTPUT_FILES= (PARAVIEW, SURFACE_PARAVIEW) % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Writing solution file frequency OUTPUT_WRT_FREQ= 5000 % % Screen output SCREEN_OUTPUT= (INNER_ITER, WALL_TIME, RMS_DENSITY, RMS_MOMENTUM-X, RMS_MOMENTUM-Y, RMS_ENERGY) Last edited by Lucifeanix; June 30, 2022 at 03:47. Reason: TO add new files and extra information |
July 5, 2022, 11:59 |
Try Filter
Try to use Cell to point data filter before analysing the results. This might help you.
cfd, su2, validation, verification |
[solids4Foam] Problems while validating Turek and Hron (2006) FSI2 and FSI3 problems in solids4Foam | subhasisa.rath | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | September 6, 2021 18:02 |
[solids4Foam] Problems while validating Turek and Hron (2006) FSI2 and FSI3 problems in solids4Foam | subhasisa.rath | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | September 6, 2021 17:37 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
problems with the stability of results | ingeniero_82 | CFX | 3 | March 18, 2011 07:19 |
Results comparison problems | ken87 | FloEFD, FloWorks & FloTHERM | 0 | March 15, 2011 04:58 |
