March 26, 2021, 01:54 |
ROBIN helicopter geometry
alidogrul
Rep Power: 16 |
Dear friends, I am looking for CAD model of ROBIN helicopter fuselage model. I am willing to study the interaction between a surface combatant and this helicopter model. THere are some technical reports of NASA for the generation of geometric shape. However, when I try this, some coefficients become complex numbers and I could not continue . If anyone already has this CAD model in any format like iges, step etc., I would be appreciated to get it.
Thanks in advance. |
March 31, 2021, 23:55 |
Mark Stock
Rep Power: 14 |
We found those same issues with the published data, and decided to compile all of the published corrections, along with re-cast formulae which avoid numerical errors, in an open github repository. We hope this helps.
https://github.com/Applied-Scientifi...n-surface-mesh |
fuselage, helicopter, robin |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 21:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
