Home > Forums > General Forums > CFD Freelancers
Compiled udf for finding co-ordinates of maximum stream funtion in a fluid flow domai
Old   January 24, 2021, 09:31
Smile Compiled udf for finding co-ordinates of maximum stream funtion in a fluid flow domai
Ravichandra
Ravi palla is on a distinguished road
Sir, I am a student persuing masters degree. I come up on situation where I need to extract the co ordinates of maximum stream funtion contour in a fluid flow domain using 'c' compiled udf. So the problem here is I am not familiar with 'c' and how to write the udf. Can any one help me with this situation.
Thanks in advance.
Ravi palla is offline   Reply With Quote
Old   February 15, 2021, 16:41
Default Maximum values
Clark Paterson
cfpaters is on a distinguished road
It seems like you might be using a UDF with Fluent. Is that correct? If so, I would recommend using a custom formula/function instead of a UDF. This is a much easier interface for those with less experience. You can also use some max/min functions as well. You can have it report parameters that are being produced by the UDF. Let me know if this is applicable advice or not.
Another option might to use the grid adaption functions coupled with your custom formula. You can then highlight regions and report on max values in the domain when you go to mark cells for refinement.
Best regards,
Clark
cfpaters is offline   Reply With Quote
compiled udf, flow field analysis., stream function
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
