Home > Forums > General Forums > CFD Freelancers
Looking for a 2-D SIMPLE code
Old   June 11, 2020, 08:29
Smile Looking for a 2-D SIMPLE code
Freewill1's Avatar
Freewill1 is on a distinguished road
I am looking for a SIMPLE 2-D demonstration code with following capacities:
1. 2-D lid-driven cavity and natural convection (Re value range: 1~1000)
2. based on SIMPLE algorithm
3. collocated arrangment
4. incompressible, Newtonian fluid
5. implemented using matlab
Best,
f
Freewill1 is offline   Reply With Quote
Old   June 14, 2020, 05:24
Troy Snyder
tas38 is on a distinguished road
Originally Posted by Freewill1 View Post
Best,
f
I do not have a matlab code to provide you.
But I do notice that you previously posted a lid-driven cavity code (written in matlab) for which you were having some difficulty.
Problematic lid-driven cavity using SIMPLE on collocated grid
I took a look at your code, and I think the issue is that you do not properly apply under-relaxation to the momentum equations. The momentum under-relaxation parameters are applied when solving the momentum equations and will therefore implictly impact the pressure-correction equation solution. They will affect the stability and convergence rates of both the momentum and pressure correction equations. See Section 6.4 in Versteeg and Malalasekera (1995 copy) for more details on this.
In your code (see link above), you apply relaxation to the u- and v-velocity components at the point at which the pressure correction equations are applied. Something like u = u^* + \alpha_u u' --> This is NOT correct. Note that in equation 6.15 in the aforementioned text that u = u^* + u'. The under-relaxation \alpha_u has already impacted the computation u^* via the momentum equations and u' via the mass imbalance (source) terms within the pressure-correction equation.
Hopefully you can get your own code working as a result of this suggestion.
tas38 is offline   Reply With Quote
Old   June 14, 2020, 09:23
Freewill1's Avatar
Hi Troy,
Thank you for your reply, I will try to fix the bug you find.
Best,
f
Old   June 17, 2020, 06:23
Smile Bug found and fixed.
Freewill1's Avatar
Indeed, a worng under-relaxation method was used. Now new code with this bug fixed are available here:
Many thanks, Troy @tas38.
collocated, lid-driven cavity, natural convection, simple
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid h_amooie OpenFOAM Programming & Development 1 January 22, 2022 12:33
suction force in simple code sciense Main CFD Forum 0 June 8, 2015 11:02
help!on simple method code houkensjtu Main CFD Forum 0 July 9, 2011 11:45
SIMPLE code for 3_D problem bobby Main CFD Forum 1 December 26, 2000 00:20
SIMPLE code Bivan Main CFD Forum 8 October 24, 2000 22:25
