Home > Forums > General Forums > CFD Freelancers
CFD Analysis
Old   April 6, 2020, 23:26
Default CFD Analysis
ike
khattak is on a distinguished road
Please see below the tasks, could somehelp me please I am very new to this and I could use a Matlab code for the following
1. A data set of 200 frames captured using a PIV in a water channel has been provided. The depth of flow in the channel is approximately 170 mm. The width of the channel is 1.1 m. Each frame is for the same open channel field-of-view (FOV) covering from the bottom close to the bed and up to the free surface at the top. Please disregard the first four lines in the header of the date files. The columns in the data file are self-explanatory. The time difference between two data files is 0. 34 s. Assume no-slip condition at the bed. Calculate the following:
A. Using the 200 frames, calculate the mean Reynolds shear profile.
B. Calculate the friction velocity in the channel
C. Plot the profiles in the classical semi-log plot
See below only just a part of the one of the 200 files
PIVlab by W.Th. & E.J.S., ASCII chart output - 22-Aug-2019
FRAME: 801, filenames: A: bg_subtracted_WOFT000801.T000.D000.P000.H000.LA.TI F & B: bg_subtracted_WOFT000801.T000.D000.P000.H000.LB.TI F, conversion factor xy (px -> m): 7.9582e-05, conversion factor uv (px/frame -> m/s): 0.034601
x [m],y [m],u [m/s],v [m/s]
0.01225562701,0.01830385852,0.2470173739,0.0113690 4002
0.01225562701,0.01957717042,0.2406842196,-0.01047280772
0.01225562701,0.02085048232,0.2219417555,-0.01011418292
0.01225562701,0.02212379421,0.2319426942,-0.01909123597
0.01225562701,0.02339710611,0.2279459914,-0.0276101643
0.01225562701,0.02467041801,0.2289305619,-0.00880173739
khattak is offline   Reply With Quote
cfd aerospace, cfd analysis, matlab code, matlab codes for cfd
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
How do you do a fluent CFD analysis for a boat? UHMStudent FLUENT 2 July 24, 2011 13:45
CFD software capable of modal analysis? Jim-gineer Main CFD Forum 4 January 14, 2010 10:29
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
CFD Analysis on Shock/Boundary Layer Interacton'-HELP Mujahid S. Suhaeb Main CFD Forum 8 December 1, 1999 18:14
