whether to use Shell conduction or Conjugate heat transfer model in Fluent |
Dilu
Rep Power: 0 ![]() |
I am trying to see how the heat is transfer in the solid body with different layers. (pls check the attached image). the small layer in the middle is the heat generation source and the other layers have different material. I am new to ANSYS fluent and after some research I found that heat transfer problem could be solved using Conjugate heat transfer or shell conduction. My Question is, could my problem could be solved using both method? if so how can I use Shell conduction or conjugate heat transfer model to solve my problem. Is there any resources I could look into other than the ANSYS user guide? Thank you for your time. |
Svetlana Tkachenko
Rep Power: 14 ![]() |
[mesh manipulation] Conjugate Heat Transfer Fluent Mesh Conversion to OpenFOAM | Lancia037 | OpenFOAM Meshing & Mesh Conversion | 2 | August 22, 2019 09:11 |
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit | RPjack | ANSYS Meshing & Geometry | 1 | June 20, 2019 07:11 |
Conjugate heat transfer: coupled wall temperature | Sarah | FLUENT | 7 | August 12, 2013 22:36 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Conjugate heat transfer, thermal boundary conditions | Sarah | Main CFD Forum | 1 | April 7, 2010 07:20 |
