XFlow torque calculation problem, darrieus wind turbine |
February 10, 2020, 18:47 |
Camilo Caceres Cardona
Hi everyone,
I need help with the torque calculation of a darrieus wind turbine simulation made in XFlow. In the post-processing I can view correctly (checked) the angular velocity (wy in this case) of the turbine by the Function viewer tool. In the function viewer I can also view moments in the 3 axes but I'm not sure of these results because My values for example, are both negative and possitive and makes no sense, plus I don't know where are they located. Do you know a correct method to get the right torque in the same axis of the angular velocity to get the power in XFlow software? Thank you |
darrieus, power, torque, xflow |
Problem with forces and moment calculated for wind turbine blade using simpleFoam | mostafa kamal | OpenFOAM Running, Solving & CFD | 2 | September 21, 2021 17:33 |
Low torque values in high wind speeds for a wind turbine | Seervan | STAR-CCM+ | 5 | August 5, 2019 20:36 |
Calculating torque in a FSI wind turbine simulation | alexvaleije | FLUENT | 0 | June 1, 2019 12:53 |
wind turbine Torque for each time step (transient flow) | James Hetfield | FLUENT | 1 | March 17, 2013 20:27 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
