May 27, 2019, 10:52 |
tire simulation
Giuseppe
Hello everyone, this is my firs post on this community. I'm proud to be part.
I have to simulate the inside of a tire. My domain have a diameter of 0.65m, width 0.31m, is a toroidal domain. It is a problem of heat exchange, in which the walls, the 4 walls of my domain are in a determinate temperature. I have to determinate the temperature of the fluid (air) inlet the domain in a steady state condition. all my walls are in rotation of 80 rad/s. I would like to know what kind of mesh i have to generate, and the model of equations that i have to use. Actually i have generated a mesh with a 1st layer thickness of 0.03mm, grow factor of 1.15, 27 layer for 8.51mm of total height of the layers. All my domain consisting of 1047775 elements. I have used the k-epsilon RNG model with standard wall functions. After the simulation my y+ go from min of 0.35 to the max of 0.63. I would like if i'm simulating well my domain. thanks a lot and sorry for my bad english. |
May 27, 2019, 15:22 |
Gert-Jan
Rep Power: 28 |
This is Freelancers forum Did you read: Introduction
heat and mass transfer, layers addition, near wall distance, wall function |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
