Help with Fan with flexible serrated trailing edge (2way FSI) |
May 17, 2019, 07:24 |
Bernardo
Hi guys I'm looking for some mentorship in the field of axial fans, more specific in 2-way FSI since the aim of the project is to reduce the fan noise with the implementation of flexible material (silicone, or other) in the serrated trailing edge of the blade. This will require knowledge in dynamic meshing and transient 2-way FSI simulations in ansys fluent/mechanical/system coupling.
Thank you in advance. Regards, Ben |
May 21, 2019, 13:29 |
PEC
Rep Power: 7 |
Hai, My name is Paramesh. I can help you with your project.
You can call me at 8074810789 Or write to me at paramesh@tamminainfotech.com thank you |
fan aerodynamic, fsi 2-way |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 14:53 |
[ICEM] Hole near sharp trailing edge of airplane/wing geometry | jlichtwa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:19 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 13:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
