Home > Forums > General Forums > CFD Freelancers
How to patch/generate the Vaccuum in a fluid domain
Old   October 12, 2018, 05:19
Arrow How to patch/generate the Vaccuum in a fluid domain
mishal
Muhammad Shad is on a distinguished road
Send a message via Skype™ to Muhammad Shad
In the IR detector vacuumed dewars, the IR detectors are to be cool down upto cryogenic temperature for their better sensitivity. The IR detector is mounted on cold finger tip. The cold finger is continuously produced cooling @77k and remove 0.5W combined heat load of IR sensor and dewar. I am trying to model this Heat transfer analysis in ANSYS Fluent. But I have an issue of generating/patching the Vacuum 0f 10-10 torr for the domain shown in figure. My question is:
How to patch/generate this vacuum in the domain shown in the figure?
hashtag#Vacuum hashtag#HeatTransfer hashtag#FLUENT hashtag#IRDetector hashtag#Radiation hashtag#cryogenictemperatur hashtag#heatlifting[IMG]
https://www.linkedin.com/in/muhammad-shad-70408a54/detail/recent-activity/shares/[/IMG]
Muhammad Shad is offline   Reply With Quote
cooling, cryogenic, heat transfer, vacuum
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 08:09
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
