October 9, 2017, 16:19 |
Turbulent flow over flat plate
Vedamt Chittlangia
Rep Power: 9 |
I want to see the effect of free-stream turbulence on skin friction coefficient. For this I want to use Launder-Sharma low Reynolds turbulence model in OpenFOAM v-2.3.x or 2.2.2. The test case is zero-gradient flow over a flat plate. Inlet turbulent conditions for turbulent intensity, Tu = 1%, 6.53% and 25.7%, thus total of 3 cases. Inlet velocity will be 30 m/s for first two cases and 6 m/s for the last case.
The final result should plotted for skin friction vs Momentum thickness based Reynolds number. The results should compare with previous study done in the http://turbomachinery.asmedigitalcol...icleid=1672759literature. |
launder and sharma, low reynolds |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 15:40 |
Flat plate analysis in cfx | hamed.majeed | CFX | 14 | February 4, 2015 08:07 |
problem in turbulent flow over flat plate with stagnation point | mb.pejvak | Main CFD Forum | 0 | September 12, 2012 22:25 |
Experimental Results for turbulent flow over a flat plate | mb.pejvak | Main CFD Forum | 0 | May 18, 2012 23:20 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 27, 2007 00:26 |
