Anyone willing to do a "paid" ICEM mesh for a wind turbine blade ! |
Ahmed Riyadh Ali
Rep Power: 9 ![]() |
Dear All
I am working on simulating NREL Phase-II wind turbine blade using a single rotating frame with Ansys Fluent 18.1. I need someone to mesh the domain with ICEM Hexa mesh type to follow the literature one. The reason behind that is I am encountering a problem of getting the right torque value in which the actual value is 94 N.m while I am getting 84 N.m. To be honest I have made a number of modifications to pose the problem correctly according to Ansys Fluent Documentations as well as changing and refining the mesh further which led to a noticeable improvement of the result from 75 N.m to 85 N.m. Regardless further modifications to the mesh, the torque seemed to remain the same. So, I have started to believe it may be only Hexa mesh for my case that would lead the residuals to fall smoothly with have the mesh I am currently using. Waiting forward to hear from you guys. Thanks Ahmed |
sandy
Rep Power: 10 ![]() |
hey can you send your mesh; saddyhasan@gmail.com
i am not able to understand where exactly do i have to mesh??? |
Ahmed Riyadh Ali
Hi there guys
the problem solved. Thanks for following up. Regard |
MCD
Rep Power: 0 ![]() |
[ICEM] Holes in wind turbine blade mesh | goral04 | ANSYS Meshing & Geometry | 2 | May 25, 2016 04:19 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
TurboGrid & ICEM: Turbine and wake mesh. | Kaelon | ANSYS | 3 | June 16, 2015 11:50 |
Wind Turbine Blade rotation | mmd_knr | FLUENT | 1 | August 8, 2012 14:52 |
[ANSYS Meshing] Mesh elements inside turbine blade | eoinsturbine | ANSYS Meshing & Geometry | 2 | May 15, 2011 11:44 |
