September 11, 2017, 11:11 |
Prove hydrodynamic cavitation will occur
AJ
I am interested in creating hydrodynamic cavitation through a slit Venturi reactor. This is for the purpose of homebrewing as cavitation effect is desirable for certain steps in the brew day.
I have found this paper that models the CFD of circular and slit Venturis here: http://www.krishisanskriti.org/vol_i...0150106017.pdf The conclusion is "Slit Venturi with slit of dimension 2mm height 3.14 mm depth operating at 8 atm gauge inlet pressure, slit height to length ratio of 1:1 and divergence angle of 5.5 degree are the optimized parameters for maximum cavitational activity." I'm wondering if these results scale up as I need a slit dimension of 2 cm not mm. If someone wants to model and prove that caviation will still occur at the larger size and their optimized parameters will still hold consistent it is something I'd be willing to pay for. The main question needed to be answered is that indeed the cavitation effect will occur with a larger slit opening (or what is the maximum size slit that can create cavitation?). Thanks for the consideration. |
September 13, 2017, 12:07 |
Hello
Rohan sharma
Rep Power: 11 |
I have 8 years of rich experience in CFD analysis. I can help you in the analysis. Please mail me at rohansharmafree@gmail.com
September 18, 2017, 04:20 |
Andrey Yakovchuk
Rep Power: 14 |
Hi, I had experience exactly in area you describe. Cavitation device for oil heavy fraction refinery was developed and then, similar cavitation device for beverage production was also developed with the help of CFD and cavitation analysis.
Taka a look at pg. 9 in my portfolio. https://drive.google.com/open?id=0Bz...WVRM1pNRG5BZFU Feel free to answer questions here or by Email: yayakovchuk@yandex.ru |
Recreating hydrodynamic cavitation paper's results at larger scale | maco144 | Main CFD Forum | 0 | September 11, 2017 11:06 |
fetal overflow in user defined cavitation model | unclewallcn | CFX | 15 | January 20, 2016 23:17 |
Cavitation in Pure Ethanol | Pugnax | CFX | 4 | June 18, 2015 21:19 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 09:00 |
Combining Cavitation and Thermal Effects? | akash_max | CFX | 4 | January 19, 2012 15:09 |
