Home > Forums > General Forums > CFD Freelancers
modeling a rotational + translational periodic flow
Old   June 29, 2017, 15:28
Default modeling a rotational + translational periodic flow
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello CFD experts,
I want to model a flow with periodic boundaries. The flow is rotational as well as translational periodic in nature. (Please see attached figure). Therefore I have modelled a 3d helical periodic segment. In Fluent, under Periodic conditions, I gave MFR and Bulk temperature as 298.15. While the outer wall heat flux is 298.15 K. The contours formed for temperature are pretty strange. Since the geometry contains helical shape, the translation distance in the figure is up to 1 pitch length (12.7 mm), which is for helix angle 60 degree. Please help me, why the temperature is not resolving right? Will, the boundary conditions "velocity inlet" and "pressure outlet" (instead of translational periodic) help?
Shamoon Jamshed is offline   Reply With Quote
Old   July 26, 2017, 01:15
Saaddin Nur
niddaas is on a distinguished road
Send a message via Skype™ to niddaas
Hello Shamoon Jamshed,
Now we just finished the rotating body problem using MRF (moving reference frame).
Please contact us at http://www.faedaworks.com/contact-form/
to give more detail about the problem.
Hope we can help you.
Thank you,
Saaddin Nur
niddaas is offline   Reply With Quote
Old   July 26, 2017, 10:31
Shamoon Jamshed
I think you did not understand my problem correctly. My problem has nothing to do with MRF. The flow is rotational though, but it is steady flow.The geometry is rotational as well as translational periodic.
Old   July 26, 2017, 20:43
Saaddin Nur
Sorry for the misunderstanding. But, I think with no mrf the simulation will be easier to prepare.
Previously, we've finished ahmed body validation with error of 99.98%. Hope the experience will help us to solve your problem.
Translational+rptational periodic flow Shamoon Jamshed FLUENT 0 June 1, 2017 22:03
About translational periodic boundary conditions in Pipe flow xq712000 FLUENT 0 January 18, 2015 03:53
Periodic boundary condition - pipe flow -setting up heat transfer Explorer FLUENT 0 December 4, 2012 04:36
pressure gradient of a 2D periodic flow problem Honey FLUENT 0 September 19, 2012 04:21
Periodic boundary in unsteady flow ac2011 FLUENT 0 September 26, 2011 07:52
